Old 10-29-2007, 10:49 PM
The T56 uses a 'synchro' type of shifter block like the rest of the gears use. If the other gears shift OK, then reverse should shift OK, ruling out clutch release. More likely something is wrong with the shift mechanism for reverse itself. 5th, 6th and reverse are all housed in the tail shaft area. This is a pic of reverse gear.
