Old 10-30-2007, 03:41 PM
KarlCSX2498's Avatar
KarlCSX2498 KarlCSX2498 is offline
Cobra Make, Engine: CSX2498 has been in our family garage since '68....Scratch built aluminum bodied 427SC Cobra, 427FE, CSX3000 chassis specs, 95% finished, only needs paint.
Default almost finished
hello
yes, the registry is up to date on major and minor changes to the car. The new registry will have new photos and details. the 289 hi po was removed in '69 and a Boss 302 installed. The Boss was removed and a rebuilt 289 hi po was installed.
We did have to replace the passenger side foot box, the original radiator was replaced with a custom fabricated aluminum radiator with a rear shroud and fan. A few other small parts had to be replaced. The car needs to run normally and if a part needs to be replaced then it is replaced.
We should have everything finished and sorted out next weekend. Then it is off to the alum body guy for repairs over the winter. It should be painted and ready for the shelby convention next august in NJ. It will probably be painted the original color ....white.
Stop by any time you are in the area. regards, karl
