Old 10-31-2007, 01:23 PM
patrickt patrickt is offline
Originally Posted by Tallguy
I do have one last question... What I can not find are the dimensions for the clutch fork. I plan to run a 438 FE and a TKO 600 with a blow proof bell... I am trying to figure out what clutch fork would be used...
I believe the TKO600 uses a standard Ford small spline fork, D0TZ-7515A. They also fit Ford Trucks 73-79 L6 so the specs should be available on line, or you could just pick one up at the local autoparts store. OR, someone here might have one sitting on the shelf and would be kind enough to measure it for you, angles and all .
