Thread: jack stands
Old 11-02-2007, 08:08 AM
Nor Cal Al Nor Cal Al is offline
Cobra Make, Engine: Cobra-less
I believe I once asked Tony about front jacking and, if my aging memory is correct, he said not to lift by the cross member that the steering rack is bolted to. Therefore, you would jack by the frame rails.
I use 2 small jacks and lift each side a little at a time, then put stands as close to the front suspension as possible.
I jack the rear under the differential (pumpkin!).
AL
Cobras Gone But Not Forgotten
