Old 11-02-2007, 09:08 AM
vettestr's Avatar
vettestr vettestr is offline
Cobra Make, Engine: Cobray-C3, The 60's body lines on todays chassis technology
The talks circle back to the piston sucking fuel charge into the cylinder so here is a mind twister to kick around. If the piston is responsible for filling the cylinder what if we increase the size of the intake valve or have 2 or 4 valves per cylinder? If the bore diameter is 4 inch what if the the intake valve was 5 inch in diameter?
If the intake valve was not restricting flow or creating a pressure differential on each side of the valve when opened would the cylinder still get filled if the is no SUCTION? ( bore is 4 " and intake valve is 5 " and very high ramp angle)
Jeff Classic
Manufacturer of the Cobray-C3
www.cobrasnvettes.com
