Old 08-27-2001, 08:30 PM
Alex Evonosky Alex Evonosky is offline
Cobra Make, Engine: Building from scratch
Default Charging
If you have rubber motor mounts, make sure the engine is grounded to the frame as the battery is. Sometimes the ground from the engine to the frame loosens and creates many problems.
I use a 2 hole lug, this way the chances of both bolts being loose at the same time is very slim.
Cobracer#15
