Old 11-04-2007, 07:10 AM
jopper jopper is offline
Cobra Make, Engine: EverettMorrison,408W,Jag rear, toploader
There is a bracket on each side of the differential housing that provide a pivot for the fulcrum rods you are talking about. The only way I can see that you would be having this problem, is if the bolts that mount these brackets to the housing are backing out. Mine are lock wired to prevent this. Better check it out.
Jerry
