Old 11-05-2007, 07:58 AM
Dangerous Doug's Avatar
Dangerous Doug Dangerous Doug is offline
Cobra Make, Engine: ERA 289 FIA #2108
Default Best clutch for SB?
I figure my 331/347 stroker will be in the 400-425 hp range. As clutches are spec'd for horsepower range, which is the best clutch to use for this horsepower range without ending up with overdeveloped muscles in my left leg? That is, which clutch will provide "normal" pedal pressure?
What I've heard: Ram and McCleod (sp?) have heavy pedal pressure. Centerforce II clutches advertise "normal" pedal pressure, but I haven't had the opportunity to try one.
What say you? Which clutch did you use and do you like it?
DD
Dangerous Doug
"You're kidding, right?"
