Old 11-06-2007, 11:31 AM
greg schroeder's Avatar
greg schroeder greg schroeder is offline
Cobra Make, Engine: Superformance, Roush 427R-095, Pro Systems carb, 2" headers, Buckshot Racefab side pipes, 10s off idle start
Originally Posted by Madmiles442
So at the lauch, do you idle start and just shift up through the gears "normally"?
I've tried different rpms and can't get out of the wheelspin of my 3.73 rear end. I lose all my time with First gear and half of second just spinning away.
I pretty much start about 1200 - 1500 rpm and shift around 6800 rpm. The problem for this particular day was track surface temperature was over 100F and I suspect with it being a casual club event the track wasn't prepped as good as it could have been. Everyone was spinning. I did ask an official at the track what surface temperature would be best and he said about 85F. I brought my temperature gun and by the time racing started it was an up hill battle.
It would be nice to make a few passes with lower DA and track surface temperature within a good range.
The tires stick better on a normal road than they did at the event.
