Old 11-06-2007, 06:55 PM
venum14's Avatar
venum14 venum14 is offline
Cobra Make, Engine: Bennett Cobra
Default Red be aware!
Red is considered high strength or forever! You only need to heat it to about 300-350F to soften it up. Heat up the fastener/area until you smell the "Loctite" smell and start removing the fastener. Don't use red unless you want the fastener there forever or you will need to heat it. It is not recommended for fasteners under 1/4".
Try the blue # 242 med strength it works the best and you can still remove the fasteners without heat or breakage. I have used it on all critical fasteners and all my motorcross bikes as they are prone to fasteners vibrating loose. Also a dab will do ya!
