Old 11-07-2007, 10:50 AM
hi-tech cobra's Avatar
hi-tech cobra hi-tech cobra is offline
Cobra Make, Engine: Hi-Tech
Default Solid Rollers
Great info guys! Thank you.
Here is the cam (solid roller cam) I'm looking at. How does it look?
Duration Is 259* intake and 269* exhaust at .050. The total lift is .640
undy, Crane said their solid rollers don't have a problem like you mentioned. Do you have any experience with the Crane solid rollers?
Excaliber, do you know if the Pond block allow for the increased oil pressure needed for the solid rollers?
Will the stock Edelbrock FE alum heads work with the solid rollers or will I need to upgrade springs?
bobcowan, I know what you mean about getting accurate info for dist. gears. I got 20 different opinions from MSD and Comp Cams for my sbf roller cam...depending on the day.
Are there other distributors other than MSD that offer plug and play with the MSD 6AL? I ask because my wiring is already installed.
