Pezza,
The R.M.C. chasis was built pretty close to square.
The only alteration we have to make is on the front nearside lower control arm mount. It's 5mm lower than on the offside. No dramas though. I'll just take it off, give it a slight grind then re-weld it back on. Easy.
If I hadn't had it lasered, I would have encountered problems with my wheel alignment so its saved me a lot of fiddling and worry.
When all the engine and gearbox mounts are in place, the entire chassis will then be powder coated.
Baz
