Old 11-08-2007, 06:41 AM
priobe's Avatar
priobe priobe is offline
Cobra Make, Engine: E-M Cobra Ford FE 427 w/ Webers 48 IDA
Rdorman,
Here is the infomation
Front Brake Information
Number of pistons within each front caliper: 4 Are pistons on one side or
both sides of caliper: both
Diameter of pistons on one side of caliper (list all):
Piston 1: 1.75 in
Piston 2: 1.75 in
Piston 3: 1.75 in
Piston 4: 1.75 in
Front rotor diameter: 12 in
Rear Brake Information
Number of pistons within each rear caliper: 4 Are pistons on one side or
Piston 1: 1.38 in
Piston 2: 1.38 in
Piston 3: 1.38 in
Piston 4: 1.38 in
Rear rotor diameter: 12 in
General Information
What is the motion ratio of your brake pedal (5.5:1, 6.2:1, etc)? 6.5:1
If using a Tilton pedal assembly, please provide part number: - Vehicle
weight (with driver and fuel): 2350 pounds Vehicle Weight Distribution (with
driver and fuel): 50 / 50 Vehicle wheelbase: 90 in.
Front tire diameter (outer): 25 in
Rear tire diameter (outer): 25 in
What is the vehicle being used for (street, road racing, circle track, drag,
etc)?: street
Yes, the rotor has been indexed.
Pads are Wilwood not sure of the compund I would assume soft
As for the pedal feel I would say hard as a brick - but honestly I just want to stop
Rotors Rear are 12" cross drilled / slotted Wilwood
Rotors Front are 12" cross drilled only Wilwood
M/C are located upper foot box
