Old 11-09-2007, 08:08 PM
macloft macloft is offline
I found on the Harrison that for the top boot mount if you drill a hole in the boot rib you can get the 2 nuts in for the counter sunk screws then put in a rubber bung as per the photo. For the lower mount i had to make a steel plate welded to the mount bracket that spreads the load undernearh the fibreglass (I used silafex to bond it to the body plus 2 screws to fasten to the boot channel) as the boot lip does not have enough strength and flexes.
Bruce
