Old 11-10-2007, 07:30 AM
troll troll is offline
Cobra Make, Engine: none
Those little tiny drive gears on the distibutor arent up for much.Its good to have them break and kill the motor when you loose oil pressure.Its just to much of a strian for such small parts. All you real need is to replace the oil on those bearings at a constant rate.If the pressure drops off at high RPM then you need wider gears in the pump its self for more volume.And glue magnets in the oil pan.
