  #33 (permalink)
Old 11-10-2007, 07:25 PM
rwall49's Avatar
rwall49 rwall49 is offline
Cobra Make, Engine: HM Ford 351w
I just had to post a reply for post #197 as just a note to Tremec TKO 600 owners who are about to install their drive shaft. There is a rubber shipping bushing around the output shaft on the transmission that must be removed before the drive shaft yoke will fit in. It's about 1/4 inch thick and about 2 1/2 inches long an it will pull out with a pair of pliers if you work it out slowly. The reason I know this is because I was trying to put the drive shaft yoke in the transmission with that piece still in there and there just wasn't enough room for both. I called Denny's driveshafts and he told me that I had to remove that piece before the yoke will slip in.
