  #42 (permalink)
Old 11-11-2007, 12:51 PM
BOURRET's Avatar
BOURRET BOURRET is offline
Club Cobra Member
Cobra Make, Engine: Paint:Metalflakes Royal and Abalone stripes registered in France in 1973. Engine: Ford Shelby aluminium block, 482; two 4-barrels 600cfm Holley; Edelbrock Performer Aluminium heads,,fluid damper,4-speeds Aluminium Toploader (short), 2.88rear
Send a message via Skype™ to BOURRET
With FE 489 cu.in.(alu block) running steady :
my normal oil pressure is 75PSI at 2850rpm
with oil temperature of 125°F
and 72 mph (130km/hr)
with an outside air temperature of 60°F .
Oil is synthesis 5W40.
When I start the engine, the initial oil pressure goes up to 120 PSI at 800 rpm and I let it warm up and drop until it reaches less than 100 PSI and a minimum temperature of 110° before moving the car.
At steady idle, in traffic, the values are:
800rpm
125°F (oil)
30 PSI.
Queenie
