Old 11-11-2007, 04:11 PM
venum14's Avatar
venum14 venum14 is offline
Cobra Make, Engine: Bennett Cobra
There is no substitute for cu in. More torque and horsepower at lower RPM comes from displacement. The 300+ in small block stroker kits are good but you can't use a long enough rod with the short 302 deck.
Go with a 351W and spend the money on cylinder heads, you will develop more torque and hp with longer life, lower oil useage. The 331/347 strokers have the oil rings near the wrist pin and the pistons are short causing rock in the cylinder thus using more oil.
My $.02 worth. It all about what you want and are comfortable with running.
