Old 11-11-2007, 07:38 PM
Default Enclosed air box Al
Al Pace if you seal and enclose an air box to the top of the throttle body's and have a single inlet, this system might work. You could have no vacuum or air leaks at all to get the correct air flow readings. A batch FI system or sequential FI system works great without Maf sensor by use of a Map sensor or Alpha specs from the coolant sensor, TPS, and Air temp sensor, O2 sensor will keep the A/F in the specs that are installed in the soft ware. Rick L.
