Old 11-11-2007, 08:05 PM
olddog olddog is offline
Originally Posted by Anthony
I'm guessing you'll then be pumping a mixture of oil, blow by gases, and air to the bearings.
The oil coming out of the oil pan sump would be exactly the same as what the internal pump is pumping now. The only differance would be that the oil is being pumped by an externally mounted and belt driven pump. The pump should not add air to the oil.
Actually there may be available an external pump designed for this service, although I never heard of one.
