Old 11-11-2007, 07:15 PM
olddog olddog is offline
Originally Posted by mylesdw
How about using the standard in-sump pump as the scavenge pump; all it has to do is pick oil up from the sump and push it through the filter; it could run a very weak pressure relief spring since it only has to overcome the filter. Downstream of the filter you feed straight into the pressure section of your dry sump pump (no scavenge needed).
A reasonable thought, but the purpose is to get the oil pump load off of the distributor, however reducing its load may be good enough.
In my industrial work with pumps, both pressure and flow impact the load on the pump. To do this, you would likely want lots of volume available, but low pressure capability. A gear pump would not be the best type of pump. That's why I like the dry sump pump, as it is off the shelf.
