Thread: Is it cactus?
Old 11-12-2007, 12:24 AM
Aussie Mike's Avatar
Aussie Mike Aussie Mike is offline
It'll only flow that ammount if it can be fed with it. Are you sure the feed from your swirl pot etc is up to it? The run from my swirl pot down to my pump is to long I reckon and the 044 can make some odd noises at times. They also don't generate a lot of suction so you need a good head of fuel keep them properly fed.
I'm going to re do the tank setup and keep the path to the pump as short as possible and the pump as low as possible.
Mike Murphy
Melbourne Australia
