Old 11-12-2007, 09:27 AM
Jerry Clayton's Avatar
Jerry Clayton Jerry Clayton is offline
take the oil pump and pickup completely off--see if the pan will go up
if not see if the main caps are bolts or studs, if studs are they longer than needed??
Look for scrape marks to see what is hitting
Your id says you have a cleveland--are you trying to put on a 302 or windsor pan?
Are do you have a Windsor and are trying to put on a Cleveland pan?
Jerry
