Old 11-12-2007, 10:33 AM
Sublime Sublime is offline
Cobra Make, Engine: B&B, 351c
Originally Posted by Jerry Clayton
take the oil pump and pickup completely off--see if the pan will go up
if not see if the main caps are bolts or studs, if studs are they longer than needed??
Look for scrape marks to see what is hitting
Your id says you have a cleveland--are you trying to put on a 302 or windsor pan?
Are do you have a Windsor and are trying to put on a Cleveland pan?
Jerry
Thanks, Jerry. Yea, I'll have to try pulling everything off again. Definitely Cleveland pans. I've tried a couple now from different mfg's. I looked for the scrape marks but couldn't get anything definitive.
I have a feeling you guys are right on about the bolts or studs. If they're studs I imagine I can trim. If bolts, guessing I'll have to get new ones??
