Originally Posted by TButtrick
Do you really want to store a car with the coil overs at full droop? I don't see how this will save you any room underneath or on top unless it's motorcycle you're storing there. The two post lifts require a healthy slab floor and can't be moved around. The Pro-Park came with free casters and you can push it around the garage with one hand.
I don't see a problem with the coil over hanging down, also you don't have to jack up your car on the lift to work on the brakes. And how many 4 post owners move the lift to work out side, most driveways are not level.
charlie
