  #62 (permalink)
Old 11-14-2007, 11:26 AM
Jerry Clayton's Avatar
Jerry Clayton Jerry Clayton is offline
Rick
No . The ctanks were drilled with interconnecting passages from the front to the rear---you could put oil in number 1 and get it to come out number 8
Ford developed a crank for the 427 that had large passages drilled thru it, sealed the holes with plugs and snap rings--I.m sure you have seen some pics
Back then , it was stated in maybe an SAE paper or something similar that the centrifucacle force whould pump oil at 7000 rpm---
Up until then it was necessary to have enogh pressure to overcome c force of 1/2 the main dia at x rpm
Jerry
