Old 11-15-2007, 08:20 AM
Clois Harlan's Avatar
Clois Harlan Clois Harlan is offline
Default Hazard Flashers alternate wiring
I want to use a lighted rocker switch for my hazard lights but I am not certain how to wire everthing up. I am using a painless wiring harness and to wire up the Flasher you are instructed to connect the brown B+ wire to your righ turn signals and your purple B+ wire to your left turn signals on opposite post of your toggle switch. IF I use the lighted rocker switch I have three posts and they are labled:
top post .... Ground
center post..Power/Load
bottom post..Accessory
the diagram shows the open circuit between the "Accessory and the Power".
Any suggestions would be greatly appreciated...and if I can't use this type of switch that's OK too!
Clois
"Let's roll"
"Be part of Something Good
