  #33 (permalink)
Old 11-15-2007, 11:57 AM
priobe's Avatar
priobe priobe is offline
Cobra Make, Engine: E-M Cobra Ford FE 427 w/ Webers 48 IDA
rdorman,
I know you have been mentioning the bedding process but I can not stop hard enough to get the pads to bedd
FAQ #2: What happens if I can't do the bed-in right away?
Often times, weather or other conditions can prevent one from fully bedding-in the brakes before having to drive the car. Fortunately, this is not a dire situation. If you are running new street/performance pads and rotors, remember that they are designed for the street and will slowly bed-in by themselves over time. Typically just a few stops from moderate speeds will start the bed-in process for normal driving.
Undy,
I am think I might order the 5/8 for the front anduse the one chrome 3/4 that works for the rear. If this seems like it works then I will order a new 3/4.
Drafting a letter to Tilton executive team.
Honestly is there a difference between Tilton and Wilwood Cylinders ?
