Old 11-15-2007, 05:33 PM
Naumoff's Avatar
Naumoff Naumoff is offline
Cobra Make, Engine: Unique 427 S/C 427 FE S.O. 484 cu in
Originally Posted by 951mat
Tony it was great meeting you as well. My dad and I enjoyed ourselves greatly. I don't think my engine let go as bad as yours, but the results might not be to different. I did find 2 broken valve springs and pulled the heads. I figured I may as well pull the motor to freshen it up some. I found the #3 rod bearing spun and feel lucky thats all it did. The crank has some cracks in it as well. So a low end rebuild is in order with a new crank and lots of misc parts that add up quick. I'm sure you know the routine. It will be dyno tuned as well, so maybe I'll knock off a half second next year. Hopefully we'll see you then.
Mat
Ouch Mat. I feel your pain.
If you have to go with an after market crank.
Scat crank snouts are inconsistent. I don't know yet if the crank bolt was not torqued properly or the harmonic balancer was not able to be pulled in tight as it didn't fit properly on the crank. the result was the crank gear cutting through he woodruff key then the cam stopped turning.
I am going to magnaflux the crank to make sure it is not cracked at the snout. I am leaning toward the latter as I have two friends that had the same issue with the snout diameter.
My engine has less than 2000 miles on it. I only laugh to keep from crying.
