Old 11-16-2007, 04:21 PM
jperickson2001's Avatar
jperickson2001 jperickson2001 is offline
When I got the car it had trans oil in it, and I assume it had it for 6 years prior. Don't know if it's world class or not, but I know that for almost 9 years now it has run in oil. When I switched initially from regular oil to a teflon based synthetic trans oil, it shifted much improved. When I switched recently between the teflon based synthetic oil to synthetic mixed with 30 to 40% Lucas shifting is off the hook. It's not as much a heavy oil as it changes the lubricant you are already using to stay on the moving parts and not come off. Dave, I'll let you drive my car around the block if you want so you can see for yourself that it's off the hook. -John
"What's behind me does not matter"
