Old 11-16-2007, 09:34 PM
JWheaton's Avatar
JWheaton JWheaton is offline
Cobra Make, Engine: ERA 389 427s/o
Originally Posted by CHANMADD
I have never heard of chaining an engine to the frame of any car. If the motor is jumping around you need new engine mounts and if you have so much torque maybe solid mounts,but chains???
Torque strap - chain same difference.
Engine mounts were fine. The engine had a good amount of torque that was released by the lifting/twisting of the engine on the frame. All was tight.
On the ERA a small amount of flex will result in the pipes lifting enough to hit the body work.
Chain (and only 1) goes from drivers side rail to block. Engine does not budge. accomplishes the same thing as the strap.
