Old 11-18-2007, 12:23 PM
Woodz428's Avatar
Woodz428 Woodz428 is offline
Cobra Make, Engine: Coupe,Blue w/white stripes SB; Roadster, Blue w/white stripes BB w/2-4s; SPF installer/Hot Rod-Custom Car builder
DOH!!! I re-examined the 2-4 log and realized that I had it setting on the next 2 intake bolts forward, they lined up,when they are on the correct bolts they set back more. I don't have the oil fill tube in it, so it went forward. If the fill tube was installed it would have hit that and not been able to locate forward, as I had it. It would be interesting to know the measurement between the nipples on the single 4 barrel. The log is also shorter overall or it wouldn't clear the fill tube. That's what happens when you don't make sure the parts are setting in their correct spot.
WDZ
