Old 11-22-2007, 04:59 AM
Default You don't need no stinkin top
Jersery Cobra It's 60+ degrees today and the sun is out. You can leave the top at home. Wear hats and jackets. If you can't find the correct hardware for your hard top, try a Lowes or depot for the latches you are looking for. I am sure you can find something that will lock on the top. Why is the top popping up?? Is the windshield bending back? Body twisting? Latch hardwear not holding? Is there a foam strip in the front between the top and the windshield support? if not the air may be getting under here and cause the lift. What does FFR say. Give them a call for any ideas. Rick L.
