Old 11-22-2007, 05:43 AM
Default I use antiseize on my pipes Sal
Sal I have slip on pipes on my ERA. I use either a heavy coating of antiseize, for the street pipes or the high temp permatex (copper) for the race pipes. The pipes need to be clean when running the copper paste. If you let the motor idle and build up a little heat, then cools down, it seals well. When you are keeping the car original, exhaust leaken from the pipes is a pain, but Sanderson makes pipes with round clamps that seal great but are not orginials. Sal when you put your side pipes on, are the head pipes loose? If you back off a couple of threads, this makes it easier to get the side pipes on and then tighten the head bolts. This works for me, I also have heat rap on my header pipes. This also quiets noise from leaken pipes. Have been told this rots out the pipes, 8 years and no problem, My pipes are coated from ERA. Make sure you use antiseize on all the bolts and nuts. You can wipe the extra off.
