Old 11-23-2007, 03:58 PM
Justin O'Rourke Justin O'Rourke is offline
Hi; First loosen all of the bolts that hold the pipes to the heads. Then remove the tab bolts that hold the engine pipes to the sidepipes. Then remove the bolt(s) on the rear hander of the sidepipes. Now wiggle the sidepipe loose by moving it up and down and inward and outward. It would help if you had someone pulling on the sidepipe where it turns into the fender while you are doing the wiggling at the rear of the sidepipe.
