Old 11-26-2007, 06:07 AM
Wayne Maybury's Avatar
Wayne Maybury Wayne Maybury is offline
Canadian Gashole
Cobra Make, Engine: Johnex 427 S/C, 351W, 472 HP, 444 lbs. torque
I did the same thing a couple of years ago and I came up with a good way to make the connection to the foot boxes and also to shut the air flow off when it is not required. I found 2 old throttle bodies from 5.0L engines which I mounted on the footboxes. I got a couple of vacuum actuators (sp?) from an older Mopar heater/AC unit which I mounted on fabricated brackets. The air flow can now be easily turned on or off. The only problem is that I don't get as much air as I would like to have especially on really hot days.
Wayne
Don't get caught dead, sitting on your seat belt.
