Old 11-26-2007, 06:19 AM
Woodz428's Avatar
Woodz428 Woodz428 is offline
Cobra Make, Engine: Coupe,Blue w/white stripes SB; Roadster, Blue w/white stripes BB w/2-4s; SPF installer/Hot Rod-Custom Car builder
The floor shift versions are different than the column shift ones, and I believe that is the floor shift style. If so then all the way back should be park. It's very easy to tell since park is just a "ratchet pawl". With a yoke in the tranny, rotate the yoke while you move the shifter from one extreme to the other, when it's on park it will stop rotating. The pawl will be locked, that's park.
WDZ
