Old 11-26-2007, 12:16 PM
priobe's Avatar
priobe priobe is offline
Cobra Make, Engine: E-M Cobra Ford FE 427 w/ Webers 48 IDA
Jac Mac,
I see that makes perfect sense.
Here are the bore and stroke info.
4.232" X 3.784"
Cam specs
Intake and Exhaust
Lobe Separation= 111.9 Cam Deg
Valve Overlap= 23.4 Crank Deg
Intake
valve open = 14.6 Cam Deg
Centerline 115.8
Valve Close= 50.2
Duration------> 244.7 Crank Deg
lobe lift ------> .37689 IN
Valve lift-----> .65956 IN
Lobe Area ----> 30.85 IN * DEG
Exhaust
Valve Open = 60.5
Centerline = 115.8 BTDC
valve close = 8.9 ATDC
Duration----> 249.3 Crank Deg
lobe lift ----> .3789 IN
valve lift ----> .66307 IN
Lobe Area ---> 31.83 IN
Compression Ratio = 9.5:1
My driving style is mostly street driving with sometimes aggressive manner.
Please let me know if anything else is needed.
My comment about the MSD was that I was thinking it might be a MSD 6AL problem. I was told that the 6AL does not operate above 3000 rpm with the multiple spark discharge. That may be the MSD might be bad. ( I dont know anymore I am throwing up my hands)
I was also thinking of returning the carbs back to the setup list below
37 mm choke
60 idle
120 holder
f-7 Etubes
210 air
160 mains
55 bleeds
Just to see if I still have the problem.
Suggestions ????????????
