Old 11-26-2007, 06:34 PM
LMH's Avatar
LMH LMH is offline
You should be able to see the offset in the pins. Install them so that the bellhousing is moved in the direction needing the offset. (in your case, shifting it the side.) Make sure both pins are set the same direction. Then re-check the alignment.
A little tip; I usually write my results on the bellhousing, at the pint the measurment was taken.
HTH,
