Old 11-27-2007, 01:07 AM
Jamo's Avatar
Jamo Jamo is offline
Super Moderator
Whatsa...if you fail to distinguish between Turks and Armenians, you do need some rest.
I'm experienced enough not to opine as to what might occur at so early a stage and without knowing all that should be known. That is for uninformed talking heads, or tapping fingers, as it were. I'm also experienced enough to know that folks commenting on what tactics should be used by looking only at what is known, generally fail to tactically consider what might not be known...rather embarrassing at a negotiation table or before the bar at a later stage.
You can type for eternity as to why you think you know something because you saw a circle from a "near-daily proximity"...it's really not being a part of the circle, is it. And now Hollywood and international politics somehow affect the very essence of our appreciation of these little bastardized cars. You've really run out of tantilizing tidbits for pleading with folks to pay attention to your oft-repeated ramblings...and then, at long last, you finally suggest that you might be lacking a few watts to see what the dark hides.
When one realizes their zipper is down, it is best to proceed carefully so as not to catch oneself on the way up.
Jamo
