Old 11-27-2007, 10:13 AM
Clois Harlan's Avatar
Clois Harlan Clois Harlan is offline
Default Headlight switch question
I have a painless wiring harness and I am wiring in my headlights for the first time on the Daytona Coupe. The headlight switch is a Borg Warner 30 amp Push/Pull with turn dome and dimmer model that came with my harness. The wires in the Painless wiring harness are labled "headlight switch" are as follows:
Battery B+
Brake (white 14 GA)
Headlight ( Red 14 GA)
Dimmer (blue/red 16 GA)
Dash Brown 18 GA
Tail Brown 18 GA
Park Brown 18 GA
Posts on the switch are marked: Batt AUX Park Tail Dash Head
The only questions I have are where the white Brake wire and the Blue/Red Dimmer wires should be connected. I know the Blue/ Red wire has another lead that goes to the dimmer switch for the high/low beams.
Any help would be appreciated.
Thanks,
Clois
"Let's roll"
"Be part of Something Good
