Old 11-27-2007, 09:39 PM
sambo's Avatar
sambo sambo is offline
I've gleaned a few install tips from the audio nuts on another forum:
- With open top cars, it's important to have midrange/high range speakers in front of you as much as possible.
- Jaycar response kevlar splits are good value for the above.
- Run speaker wire down the opposite side of the car to the power wire.
- Audio system grounding wire needs to be the same or larger than the 12v+ supply.
- You will need at least a 10" subwoofer to overcome the bass from the pipes, otherwise don't bother.
No doubt Sideshow and others have a lot more to share - just thought it was timely for your installation Baz.
Paul
