Old 11-27-2007, 09:37 PM
Power Surge's Avatar
Power Surge Power Surge is offline
The rear needs to come out of the car, and be set up. The pinion nut sets your lash and preload, and that's done with the rear cover off, checking the gears with dial indicator, and you need to check the nut torque, gear lash, and the drag torque. It's not just a nut that holds the flange on.
Sal Mennella
