Old 11-28-2007, 06:06 PM
CHANMADD's Avatar
CHANMADD CHANMADD is offline
Originally Posted by Jerry Clayton
You need to close down the nose of your car and make the air go around it--I looked at your gallery and if you could lower your cage some, take off the windshield, cover the open right side, you could run many mph faster--fix your chevy, make the car faster and then put a ford in it at a later date, your probably making the power you need now---you aren't going to get the job done with a 800 hp wether its a ford or anything else---don't throw out the gains you have made as the other engine will be a whole new path--there are two reasons you don't see any fords in prostock and they are Mopar and GM
Jerry
I agree withthis analogy. That windshield is like a massive airbrake.:
