Old 11-29-2007, 05:19 AM
Jac Mac's Avatar
Jac Mac Jac Mac is offline
Cobra Make, Engine: DIY Coupe, F/T ,MkIV.
Priobe-
Idle fuel jet--------75
Idle jet holder -----110/120
Main fuel jet-------170
Main Air Correction-130/140
Pump or Bleed------55
Choke size---------42mm
Check your fuel pressure (running & as close to carbs as possible- remember webers dont like high pressures)
From the info you have given it looks like your main problem has been the air correction size- dont forget to check the advance curve out as well.
One other thing that helps is any form of anti-reversion cone in the exhaust primary pipes- really smooths out the idle on a setup like this.
Jac Mac
