Old 11-29-2007, 03:48 PM
400TT's Avatar
400TT 400TT is offline
I've never coated the entire surface, now that would be harder to remove. Haven't seen a need to.
Just enough to provide enough support, you could do a W pattern 50-100mm between the vertical strokes. On upside down surfaces you would use a tighter pattern, on vertical surfaces you would use bigger gaps. And run around the edge as mentioned. I hope that makes sense.
www.absolutepace.com
