Old 08-31-2001, 09:31 PM
dave hendon dave hendon is offline
you haven't mentioned what type of advance your dist uses,
if it has a vacuum advance,disconnect it to set the 6 deg.
my cobra has a 351w with a mallory dist that has a electronic advance module.in order to set my timing i used a light that can be adjusted so that all you need is tdc marked, i then rev the engine to 3000 and set my timing to 36deg, these are the numbers i found in my cam specs.
dave
