Old 12-01-2007, 02:26 PM
Tenrocca's Avatar
Tenrocca Tenrocca is offline
Heres a basic list of what you need - might be a few things missing:
Pedal
belt tensioner\belt
alternator (ls1 or use a smaller one)
P/S pump if running PS
engine harness
oil dip stick and tube
starter
maf sensor (if using maf)
front O2 sensors (2) - "supposed" to run rear o2 sensors
E38 (ecu) - Needs to be programmed without vats etc
Engine mounts (rubber donut things)
right hand engine mount bracket - in most? installations you need the corvette type bracket, as the holden one puts the engine off centre.
Bolts to hold everything on!
If wiring it yourself (try www.currentperformance.com for all this):
Pedal connector
Maf connector
2nd ECU connector
OBD2 connector
relays\fuses (Im using their stand alone fuse relay module)
My suppliers - bay city holden (frankston) had great prices on the harness ($250) and tensioner, pedal etc, found alternator\ecu\ps pump\starter on ebay, current performance, and www.rockauto.com.
