Old 12-02-2007, 12:43 AM
Jac Mac's Avatar
Jac Mac Jac Mac is offline
Cobra Make, Engine: DIY Coupe, F/T ,MkIV.
Smile
There is no center/middle oil drain on a 351c head gasket, there is also no 'Top' mark on the gasket, only a 'Front'- easy check- most Ford SB head gaskets[incl 351c] have a 'square' corner at lower front on both sides- for most production gaskets. This also means one gasket will appear to be upside down when fitted.With reference to the 351c, provision is made for in/ex notches to allow fitting to both sides. Aftermarket & SVO gaskets can be left/right handed for the ex/in notches in some applications and are marked as such.
With ref to your problem, someone hasnt left a bit of rag or paper towel etc in the drain back holes at each end of the head while fitting valve springs etc have they, I did a 200mile round trip to find that one night after a 'clever gent' didnt remove them after changing springs and ended up with the same problem your dealing with - I was not a happy camper by the time I got home!!
Jac Mac
