Thread: Photo gripe
Old 12-02-2007, 02:29 AM
Ron61's Avatar
Ron61 Ron61 is offline
Post
Rwilla4,
Setting the new cameras to the highest setting is a total waste of time, battery power and space on your memory card unless you are a professional photographer. I use a mid range setting and print 8 X 10s that are very good. If you are going for larger, then I agree with you. Most of my pictures are in the 900 to 1.5 mb range and are easy to downsize to post. If I do run into something special that I want a high rez picture of then I will set mine higher for those pictures.
Kristen,
You need to get your own server and put your pictures on it. As for your Cobra Goddess Title, that has been replaced with Senior Member because the Mt. Shasta Goddess has taken over.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
